sunshinedaydream
- Jul 2, 2007
- 27152
- 117
Yes, what is that for?
The big question is it 12 or 24 volts? I would assume 12 but not knowing what it's for I would meter it just to be safe!
Originally posted by chriscraft67
Do yourself a favor and screw the cap on it and forget it. You will find nothing today that will mate with those contacts. You could remove it completely and install a cigar lighter fixture and then use it to charge your cell phone or other low current device.
I know its salty looking but it serves no purpose today. If you do decide to replace it with something more modern, whether you smoke or not, you might want to check the wiring behind that old plug.
Originally posted by rawidman
The common "cigarette" (cigar) lighter socket design was great for its original purpose. When the element got hot, it was pushed out of electrical contact and ready to light a cigar.
It makeas a lousy 12 receptacle because there's nothing but a point to point contact for the positive electrical connection. If it's just a bit loose, the connection is broken.
Strangely, nobody has managed to replace it with something better even though it would be simple and cheap.
