Marine Tex is the easiest, but softer than some epoxy's with filler. Ideally, fill the hole with Marine Tex or epoxy with high density filler, push around with a toothpick so it mushrooms inside, then redrill the hole, counter sink the outer part, and then put in with 5200 around the screw.
