Q&A
Q: How often do I need to thoroughly clean Sunbrella?
A: The best way to keep Sunbrella brand fabrics looking good is to simply clean them as needed. Rinse off dust and dirt, wipe spills as soon as they occur or spot cleaning soon after stains occur. Removable cushion covers may be machine-washed in cold water with mild laundry soap and air dried. For more stubborn stains, Sunbrella fabrics are bleach cleanable.
Q: How do I clean my top/canvas?
A: Your top fabricated with Sunbrella fabric is easy to clean and maintain. The key to having a beautiful top for a long time is to simply rinse your top (and boat) after each use with clean water. This prevents build up of dirt that is hard or impossible to see. Then occasionally your top will need a thorough cleaning, which once again, is an easy project for the boat owner.
Q: How do I remove mold and mildew?
A: Sunbrella fabrics will not support the growth of mildew, but dirt on the fabric will promote mildew growth, which makes regular cleanings important. Mold and mildew can be cleaned and removed from Sunbrella fabrics. No set timetable exists for when fabric should be cleaned, and the local environment has a great deal to do with determining cleaning frequency. Cleaning is required less frequently in a dry environment than in a humid one with heavy foliage.
