Chart chips
My Navionics charts work just fine for my needs. I can easily zoom in for a more detailed view, or zoom for a better overall view.
I also keep paper charts at the helm at all times, and while I often do enjoy referring to them, I haven't had a real NEED to use them for years.
I saw navionics while checking out new chart plotters. The sales person didn't believe me that the Cmap had more soundings. I had to bring the Cmap chip in and show him. Yhe part that bothers me is i know the info was and hopfully still is there. It just made things so much easier seeing it than rather trying to go find it with the depth finder. I remember riding around in a small area four a half hour trying to find some little spot on the depth finder. Doing that now just makes it not worth while. One of my machines zooms in well and the other doesn't. again its a old thing verse new... I did like the zoom with the nav.
How did we start talking about Navionics?
Scottath, if you're two CP1000's are showing different things, then you must have different settings OR different s/w versions. Did you check the s/w versions with our Tech Department? There is also a MAX feature that offers preset modes. Also you might have 'flexi'zoom turned on in one and standard zoom on the other, which will affect the way it appears to zoom in. Also - is the new card showing more detail than the background chart when there is no chart in the plotter? If not, you may have a faulty card that isn't reading at all (those world background charts are pretty detailed these days!). Definitely contact Standard, check the s/w versions and the settings. Also, you can send me a general lat/lon or harbor name and I'll send you a screen shot of what it should look like, to compare with your older chart.
Why is there garble in my screen name?? I'm thinking this site is not compatible with Firefox?
I would like to see: 27 48.514N, 082 44.825W
Les's anti spammer SW desent like the at sign.
"Why is there garble in my screen name??"
Amy, your screen name uses a symbol that is used in email addresses; the forum software "garbles" email addresses to foil email address collectors. As a result your screen name Amy a t C-Map gets translated into something else...
Ah, that makes sense. So I'm now AMY (AT) C-MAP.
Scottath - I just looked at the Maptech link, thats a topo map with the '7' in the middle. Choose the Nautical Chart tab and compare again. I'm going to take a screen shot of this (and your location too Bruce) but have to ship a few more updates before the weekend. I'll be back.
Hi AMY, Navionics was a chip that was shown to me while looking at new chart plotters. It may have been where I saw a Marina/store listed which i know has been closed for years.
Both cp1000s read the chip the same way. One cp1000 zooms in better than the other. My nav chart reads at least 5 miles out( I didn't look to see if it went more) where the bathy only reads about 2 miles out.Very limited soundings past the 2 miles. Maybe 1 sounding every 1/2 mile??
Thanks for pointing out the topo verse nav chart on my maptec link you were looking at. My old chip lookes like the topo and read like the nav.
The new Cmap chip I have looks like the nav maptec and has alot less soundings. My bathy chip has about the same soundings as the link nav setting........My harbor area reads the same on both new and old chips.
ONLY 2.... there's many in between, NO ?
Mark
Originally posted by Les Hall
It is unfortunate that the priority of chip makers is satellite photos, marina locations, 3D courses rather than the hard data, like soundings, required to navigate from point A to point B safely. However, the more important lesson here is that we seem to have far too many people on the water who haven't a clue about coastal navigation, can't read or plot on paper charts - or worse - don't want to. To me, there are two classes of boaters; boat owners and mariners. A mariner understands the nature of the sea and the complexities of navigation. A boat owner operates a boat like it's a car - just gets in it and drives.
we are still waithing for the screen shot from AMY
After about 4 years I decided to get updated Blue Chart for my Garmin 2006c. I installed it and now it shows me crossing land as I come in the inlet...kind of disconcerting. I called Garmin and they basically said its not their problem. Suggested that I fill out a trouble sheet with lat/lon showing area that is incorrect so that they can address it when they print the NEXT version !! So, they want me to do their charting for them! Gave them a suggestion of my own. They blamed Blue Chart....I blame them for using Blue Chart.
Better yet they will want you to pay them for the new charts needed because of you showed them their error.
As far as I know none of them get their own data; it all comes from the NOAA. So if the paper chart is in error the electronic one will be too.
where is Amy's response to the missing detail posts above????
its in the mail
Issue resolved from CMap
I'll find out next week. Seems liked they pulled out all the stops to try to get me back to what I had.
Les ...... did you make a few calls.......
but..... I still would like to see the comparison of display vs actual chart she promised.
I'm not sure Amy gave a blanket offer to all. I thought it was directed more towards my harbor. I do know from all the chips I viewed that there were no differences at the harbor level. The difference was further out where another chart was covering the area. Alot of that parfticular chart had less soundings than my original chip. I'll find out next week when the mail comes if I now get my original chip eqivilant. :0)
Originally posted by pdecat
C-Map cartography DOES have all the bottom detail that you will find on the paper charts, even the MAX cards that cover such massive areas. It's in there! If you find things on your (current) paper charts that are not on ours, let me know.
I guess i have never seen Cmap data displayed then or does the typical plotter filter out detail??
>>>>>The ghost marina was spotted while looking for a new chart plotter. I was shown plotters with navionics chips and Cmap. I didn't remember which chip had the false information.
For the heck of it I just turned on my cp1000 with the c map chip and found that Cmap was not the one . The information is correct on C map.
