Choke problem
I have a mercrusier 7.4 1993 with carb. It has a mechanical choke and will not start unless I hold choke closed by hand. Can the bimetal spring be replaced or is there an easier fix? Thanks
The adjustment is loosening the 3 screws holding the black plastic cover and rotating it til the choke plate just closes in cold temps.
