- Aug 5, 2008
- 30499
- 6,405
Originally posted by walterv
Originally posted by Gregory S
Dave, is that necessary? can't the compressed air blow accross the pump and empty it all?
No it is not.
Walter give some thought to this I'm connecting the compressor to the city water hook up this put pressure in all of the lines right up to the pump which has a check value and prevents the water from backing thru it so where does this water go if I don't open the fitting? I can answer this because I made the mistake of not doing this once. That water will sit in the hose and the output side of the pump and then freeze and crack either a fitting or the pump or both. When I open the hose a bit of water is blown out that otherwise would have remained. So I will continue to do it my way!
