cold cranking amps....
ed flanagan
always have to learn the hard way....got 2 new dual purpose batteries(625 cca) to support my new peninsular 310 turbo('93 albin 28 te)... seems i have to go to "both" on the battery switch to start sometimes. i thought i had charging problems.. i looked in the engine manual and it says i need a 1100 cca starting battery... so my question is if i get the bigger battery, can i put the other 2 in parrell and use them as the 'house' battery. or do i need to get a 3 position battery switch if there is such a thing.
thank you
peeequalseyeee.
