I had the marina do a compression test on my Crusader 220 hp 305 cubic inch 8 cylinder engine. I do a lot of low speed trolling durning the boating season. The results are posted below.
Cylinder 1 160 Cylinder 2 125
Cylinder 3 135 Cylinder 4 130
Cylinder 5 110 Cylinder 6 135
Cylinder 7 135 Cylinder 8 150
The owner manual says that 130 psi with a range of 130 to 170 to be unifrom within 10 psi. between cylinders. The marina has indicated that the normal is approxmatelly 150 psi. The marina has recomended a valve job as they feel there may be burnt valves. What should the is the median compression for this engine.
