- Dec 4, 2003
- 12527
- 727
So, I have a new motor 2016, a 5.7 350hp Alpha EFI, I had experienced an alarm condition where it would put me in limp mode, but it only occurred at high RPM, I would throttle down and it would recover and as long as I didn't go past 5000rpm I was fine, so I got into the water and used a screw driver to make sure the intakes were clear as I checked all of my fluids and temperatures with a thermal gun and nothing was higher than 147 degrees. I thought maybe it was the intakes because my next trip didn't produce the alarm again, but then yesterday I took her out and coming back, the boat suddenly limped and stalled, I could start it again but it stalled again to the point where it wouldn't even run for a few seconds. Being I already blew one motor I wasn't in the mood to try for a second $12K motor so I called BoatUS for a tow, he suggested it could be an ethanol clogging issue, but I wasn't about to start the engine and rev it up, as I said, already blew one engine. I'm thinking I should change the filter and make sure I have fuel even though the filter only has about 150 hours on it. Or could it be something more nefarious?
