Originally posted by Msibley
Yes, we do sell drives.
Originally posted by keithheikkinen
dapolice,
Good information you have and seem to have a good handle on this already, so I'm certain I'm of little help here, but will offer what I can. I decided to simply extend the harness to have the ECM in the cuddy so it's out of harms way. Don't really need to get to it much.
Had not considered the O2 simulator and not at all sure how that works. Any idea how it "tells" the ECM what to do if not actually in the exhaust stream? How would the wide band change things, exactly? Very interested in this as it's the one area where I have not been able to find a resourse able to answer this.
Holley said they did not have a specific "marine" distributor, or would have gone that way, or at least not the one that works with the C-950 I have.
Although may be a little late, very intrigued with the "returnless" fuel pump. have not found that yet, but very interested anyway. You have a source or part number?
The relay you show is close, but looks a little different but same idea. I think it will work fine. I'm thinking through a fail safe also for the fuel system that if the engine quits, and ignition is still on the fuel pump will turn off. Just in case there was a leak that developed I would not just pump fuel into the bilge. Not nearly the issue on a car as a boat. The ECM has several wild card outputs I should be able to train to do this??
Bob, what are you talking about??
Charlie, I sent you a PM (or about to)
Thanks all,
Keith
Originally posted by blouderback
Ah, very good. I've identified a number of other posts in your forum that also violate this policy on naming vendors that sell product in direct competition with boatfix.com. I wonder why you are no as vigorously editing those posts as well?
FYI, here are a few of them, so you can take care of them as you took care of this post:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=116485 (posts #5 and #7)
http://www.boatered.com/forum/topic.asp?TOPIC_ID=116537 (post #2)
http://www.boatered.com/forum/topic.asp?TOPIC_ID=96866 (post #5)
http://www.boatered.com/forum/topic.asp?TOPIC_ID=116429 (post #6 - he even included a link!!!)
I'm sure there's more. If you don't have the time to edit all these posts, I'd be glad to become a co-moderator and police the forum for you!
Love,
Originally posted by jtybt15
James,
It's gonna floor you when you find out how much a complete Bravo transom assembly/bell housing/coupler with tilt/trim and rams is going to cost. Go to Ebay or maybe Craigs list.
What I'm curious about is the O2 sensor. The BIG difference between car and boat is the water cooled exhaust system. All modern marine engines have a certain amount of valve overlap where the intake valves are opening when the exhaust valves are still closing. During idle and low speeds there is enuff lag between exhaust pulses to create a suction that pulls water from the where the exhaust and water mix. This is not the same thing that most people think happens...that water runs up the exhaust pipes from outside the boat. It may or may not be much but it has been explained to me that any water would render the sensor inoperable. I thought of making a 1" thick exhaust spacer between the head and ex manifold but my cam pulls way too much salt water back into the ex manifolds. I'm in the process of making a complete SS exhaust/muffler system that doesn't mix the water and exhaust until just before it goes out the transom about 22" from the top of the ex manifolds.
What about the water messing with the sensors?
To tell you the truth, You may be better off in the long run if you bought a boat with a bravo III already on it. Just the Bravo components will probably exceed 10k alone. It's a buyers market.
Your best bet on the right gear ratio and drive would be to check what a newer version of your boat has.
