I have seen many boats with a zinc on the shaft forward of the prop to help control corrosion. I have a stainless rudder and stainless struts (2)on JEZEBEL. I planned on a zinc on the rudder
but no way to do it on the struts. My props are bronze. Should I tie the struts and rudder together with a heavy copper cable inside the boat by using the s.s. bolts? Do I need a wiper on the shaft to tie all the s.s. parts together?
And lastly, should this cable tie into the d.c.
engine ground?
Thanks for any help,
engine ground?
