Damaged Dink...
BigGrin
The other day the Wife and I are doing some final winter storage tasks and we are moving our AB Rib to my truck and "somehow" her end droped and now I have a golfball sized chip in the Gelcoat on the bottom keel of the dinghy. I need to repair this but I am looking for a simple and easy method to do so. The dinghy stays on davits out of the water when not in use. Any suggestions for this repair appreciated. BigGrin :)
I've had pretty good luck with Interlux 2 part epoxy putty. Sorry don't know the P/N. Repaired some damage to the keel no our boat 5 yrs ago and no problems yet.
Check around for a small book put out by West System Epoxy, I think it is either free of maybe a dollar or two. Gives an excellent step by step process for making foberglass and gelcoat repairs.
Check Spectrumcolor.com for matching gelcoat, I am not sure if they would have it for AB. Thier kits are very easy to use.
Dan
This document is posted for download on the West System website.
If you want to make a perfect repair--then go with the fiberglass and Spectrum color. If the area is deep, you will want to put some build up some layers of fiberglass mat to build up and give strength to the defect. If the bottom is stained or scratched, you may settle for an easier repair--where you use Marine Tex (a white epoxy)--gel coat does not adere all that well to epoxy, so you may have to settle for the color and texture of the Marine Tex. For my RIBs--which got hard use on the rocks and barnicles of the PNW taking dogs ashore 3 to 4 times a day, we just put a sacrificial layer of cloth on the bottom of the keel each year, and then bottom painted the boat's bottom yearly. We used epoxy, like Marine Tex, for the dings which frequently happened, and repainted each season, even though the RIB stayed on the boat's deck when not being used.
