depth finder installation
phantom
I have a Regal 1800 LSR and I want to install a depth finder.
I bought a Humminbird 610 and the instructions say if you wire it to the fuse box use a 1 amp fuse. I can't find a 1 amp fuse anywhere. Has anyone done that?
It says you can also wire it to the ignition but also put an inline 1 amp fuse for that which I can't find either. Also on the ignition switch there are 3 poles all of which have 1 or 2 wires connected. If I wire it to the ignition does it matter which one I use.
thanks
