- Aug 5, 2008
- 30499
- 6,405
I have had my boat for about 9 years and in this time I have replaced the Racor filters on a regular basis. The first year I found I had bad fuel and I was fowling the filter after only a few hours I had the fuel polished and problem went away. So fast forward and I learned that changing the filter is only half of the routine maintenance. Today I decided it was time to clean the bowl, what I found was surprising! While the bowl has always seemed a bit dark it looked red as one would expect but I must of pulled out 1/2 maybe even 3/4 of a cup of dirt and sludge. It was hard to drain the bowl being the plug was clogged with sludge. So I figured I would share this experience with others to let some of you know it is not a big deal to separate the bowl and clean it out what is in there may surprise you as well! This was much easier then I expected or I would have done it long ago. I wish I took before and after pictures.
