I compounded (Aquabuff 2000) and waxed (Meguiars Yellow wax #26) my transom. I did not do the area where the name of the boat is. After a long run, the areas that I waxed had soot on them and the area that was not waxed had much less soot. I ended up using Spray 9 to remove the soot.
I realized that I need to address the soot problem, but are there some waxes that "repel" soot better than others?
Ideally, I would like to be able to use boat soap and a brush to remove the soot.
Seems like it is a moot point to wax if I need to use Spray 9 after a day on the water.
Mark
Mark
