Originally posted by Billylll
I'm still thinking it could be resistance in a ground connection to the engines gauge with the gauge reading lower and the pinned tachometer.
Bill I'm sorry, just noticed I mistakenly said 10,000 rpm and meant to say 1,000 rpm.
Just to clearify, the tach needle was at zero before turning the ignition on, jumped to 1,000 rpm when ignition was turned on and after starting the engine the tach worked properly through the full rpm range.
The tach was never "pinned"/stuck. My bad.
I am now tending to agree with you that my oil pressure differential is electricaly related rather than mechanical. I'm thinking that if I can find out why the tach went to 1,000 rpm when I turned the ingition switch to on without starting the engine, I'll probably solve the oil psi defference between the engines.
