Digital TV Box
I couldn't find the original post on this, so I started a new one.
Last week while in Newport, we did not have cable. You would think at $5/footyou would get cable. Anyway, turn on the TV through my little round antenna and I got 2 channels with alot of snow!!!
So I figured it was a good time to check out my new digital box that the US government was kind enough to buy for me!
I hooked it up and it took a little knowledge, not alot. Hit the setup button and it started to scan, after 30 seconds, screen said it found zero channels, then it started to go up, 2, 4, 6, 15, 30! 30 channels, no way.
It finished and I really didn't have 30, but I did have about 10 crystal clear channels and another 15 or so with some snow. The crystal clear channeles were great. I had all the local channels like cbs, nbc, abc and fox. I also have channels like NBC+ which was a 24 hour weather/news channel. They were crystal clear, like I was watching a DVD.
I am very impressed and all thoughts of ever getting sattelite for the boat are out of mind. I don't watch alot of TV, but when I do, it is usually CBS, NBC, FOX or ABC, so why get channels I don't need.
The box I got was a Artec T3APRO ATSC Digital Converter box. It was $45, with the $40 rebate, so I got 2 boxes for like $18 with shipping. Keep in mind you need 1 box per tv. I am thinking about adding a TV to my cockpit now that I finally have something worth watching!
Good luck!
Yep, I have similar results at my slip. I think I pulled in 20 channels but many were audio only such as NOAA or sub-channels of the big networks. While in Roundout, I did try to find channels there, no dice, not one.
Same thing happened to me last weekend. I took my small 15" digital TV (no converter box needed) to my mother's river cottage that uses an outside antennae.
Got quite a few more channels and a number of them were very clear. I just wanted to see what would happen since we're still waiting for our $40 coupon. My mother decided she wants a new TV now, so now we don't have to wait for our coupon.
In Roundout you don't need TV, just listen to the Banjo's play in the woods!!!!
Have they even invented TV up that far yet?
Just for grins, here is the other site.
http://www.boatered.com/forum/topic.asp?TOPIC_ID=116670
I, too, installed my Artec T3APRO ATSC Digital Converter box last weekend. It does work exactly as reported here. I especially like having a guide to all the programs available. I was also able to delete the Spanish speaking stations since I don't need them. For parents, there is technology to lock out channels not appropriate for kids, but I found no porn stations such as are available on cable.
What kind of Antenna is everyone using?
When I switch to the standard installed marine antenna on the arch I get 1 digital channel using the box. With a pair of cheapo rabbit ears I get 20 plus channels, but it's a hassle digging out the rabbit ears and scanning for channels every time we want to watch TV for a few minutes.
It also looks a little trailer parkish. It makes me want to put a sofa on the back of the boat and a sticker on the back that says, "Earnhardt Rules".
Sorry ... Got off the topic ... So what's the best antenna for a boat?
rabbit ears. Who cares what it "looks like" when you are watching TV?
I have the round shakespere guy?
Are you sure you have the switch thrown?
I have a switch under the TV to go from Antenna to dock.
If you have it on dock, you only get 1 channel.
Also the box has a setting for channel 3 or 4, so the channel on box and channel on tv must match.
Also TV must be set to cable, so you can get higher end channels.
I'll have to look, but I think that's what I have as well. A ship/Shore button, and a knob to adjust the gain from the pre-amp I guess.
On the shore selection with the rabbit connected outside to the shore connector, I get 20 channels. When I push the ship button, I get only one.
The marine antenna is the original 1997 installation, so it may be need to be replaced.
Or ... maybe I should just connect the rabbit ears directly to the box, and stand them up in the back of a closet or something.
I wonder how the reception would be from inside?
Thanks for the reply.
I would double check your antenna. Mine has a red light on it which means it is getting power.
I have to throw a switch to give it power as well, I think it is the spare in the A/C panel.
So double check that antenna cause it does not seem like its putting out and there ain't much too them.
>>does not seem like its putting out<<
I'll check that. Would not be the first time that's happened on my boat.
Remember, if you're trying to tune in digital broadcasts, they're on UHF, not VHF! Make sure your boat antennae can bring down UHF signals.
Not always. There are VHF digital stations and after the Feb 2009 switchover there will be many digital stations moving back to VHF.
I just use my Shakespeare passive omni antenna. I posted a few weeks back where I went from 1.5 channels to about 13-14-- all crystal clear. What you have should work.
Maybe as someone mentioned, there's an adjustment or switch back there.
I've got some new rabbit ears, but I'm using those for a TV I have in my garage. :-)
Paul
There is one of the Shakespeare antennas on the boat but I have never used it. Is there a way to test it to see if it's working? I don't yet have the digital converter box and can't currently get any analog stations where the boat is docked (Sneads Ferry, NC). I do have DirecTV but it would be great to get the local channels as well.
I think there is a device that measures gain?
May have it at radio shack.
Sometimes the attennas also handle the FM signal, pull it on radio and see what happens.
Something else to check.
My Silvertons TV wires could not be wired any worse, it was obvious to me (have a little background in this field),they did not have a clue about video when they wired my boat.
You need to check for splitters if you have am/fm/ radios on the boat.
What they did on my boat was they took the main line from the antenna and split it on the bridge, one side was a feed to the salon and the other was for the radio on the bridge. Then in the salon they took this feed wire and put it into another two way spliter, one leg went to radio in the salon and the other leg went to an signal booster (amp). Then out of the amp they had another spliter that fed the Tv in the salon and stateroom.
With this configuration the amp is usless, once the signal get's split so many times before the amp, the signal to noise ratio is all messed up and the booster (amp) is actually amplifying the noise more than the signal, result is snowy pictures or no reception.
The proper way this should be wired is:
Main feed from the antenna goes directly to the amp, out of the amp you have a 4 way spliter that feeds the 2 tvs and 2 radios. Note: Lokk at the 4 way splitter, the splitter does not equaly split the signal, some ports pass more signal than others, use the ports that pass the most signal for your TV sets.
So the moral of my long winded post is "see how your video is wired in the boat".
Next thing to check is all the fittings, in my case, I found 4 bad fittings, 2 behind the wallplates, one on the bridge, one at the cable tv connection in the stern of the boat. One bad fitting anywhere in the loop can cause a problem.
If you have to re-wire, use RG6 double braided copper cable, not RG59 cable.
Hope this helps
Dave - I'm glad you posted this. Where did you get the converter box and coupon?
Ed
Ed
Google 'TV converter box" go to the govt web site, apply for your $40 coupon and hopefully you will get it in 3-5 weeks. Then go to your favorite electronic retailer and buy one. I was in a Best Buy a few weeks ago and they had them stacked up for $59.
