digital tv
fotwins94
For years I have used a shakespeare marine tv antenna and have had no problem with receiving basic channels..My question is am I still going to be able to use the same antenna with the conversion box , and I just purchased an hdtv will this setup work with this tv or do I need a hi def antenna any help would be appreciated.....
Is DTV over the UHF spectrum in your area? If so - most loops work just fine for DTV reception.
The old antenna will work fine unless you relied on distant TV stations. The new digital channels operate on much less transmitter power. So, if the new digital stations are too weak for you to receive you may have to upgrade to an antenna with more gain.
The TV stations I use on the boat are all within a 10-40 mile range and are VHF/UHF, digital or not. I have no difficulty using the old rabbit ears on the boat with the digital converter. The rabbit ears I use go on the bridge. It has 2 telescoping rod elements for VHF, a UHF loop and a coax feed line.
I'm pretty sure the issue of "much less transmitter power" will go away if and when the switch is made to turn off analog. Everything I've heard points to stations running their current DTV feeds at reduced power since they also still have their analog feeds going. In other words, once (if) the switch is made, DTV power will be increased.
My suggestion is to leave that antenna alone unless you have issues AFTER the switchover.
You do not need to wait for the analog signals to go away to make your switch to digital. I purchased a digital tuner for my boat last season. I went from no stations to 12-18 stations depending on weather.
On a nother note, I was using a cheap metal antenna because my shakespeare was not picking up anything. Over the winter I was going to throw the shakespeare away because it was not picking up either signal digital or analog. Before I threw it out I decided to take it apart and see what makes it so much more expensive then a radio shack cheapy, other the the words marine stamped on it. Inside there is a seris of flat metal plates, that are separated and connected by coils that look like springs. Most of the coils had broke at the solder joint. I resolder each joint and now it works perfect.
So the short answer is yes your shakespeare antenna will work fine with the digital, and digital HDTV signals. The question should be are the braodcast HDTV signals where you are?
We have an old Shakespeare and it works well on HDTV.
We just changed out the TV and didn't change anything
on the rest of the system.
fotwins, you have no downside to hooking it up to your existing antenna. if it works, you're in! if not there are other antennas on the market aimed at the digital signal that may be better in your application.
the digital picture will probably be perfect with your old antenna. Perfect or non existent, there is no in between. Before you do anything else try adding the converter. You will be amazed.
....My suggestion is to leave that antenna alone unless you have issues AFTER the switchover.
Which could be years!
Right now all TV stations transmitting both analog and digital TV are running each format at half power or less. The reason is the amount of electricity needed to run these both at full power would double their monthly utility costs and exceed most transmitter locations service cabling from the grid. Once the government gets out of the way all digital transmitters will be run at full legal power. It does not effect the analog signals range as much as the DTV signal. Full power DTV will improve reliability considerably.
Regards Bill
My Jensen TVs both pick up both DTV formats and Analog. I use an amplified Glomex and can pick up either format.
