1978 mercruiser 260 hp 350. I had a dip stick that went to the botom of the oil pan it started leaking. I would like to put one in the side of the block but I dont see any way to get it past the exhaust manifold. Any sugestions?
any mercruiser dealer should be able to get it using those part numbers. as long as the block has the hole in it.some have a plug that can be removed once the oil pan is removed
