I changed marinas this year after being at the previous marina for the last twelve years. When I arrived at my new marina and plugged in my shore power cord I tripped the breaker instantly. (I have never tripped a breaker in the last twelve years, but then I don't think I had a GFCI breaker on the power pedestal.) This is a 20 amp breaker with integral GFCI. I chased the problem this past weekend but unfortunately I did not have any meters with me. Here is most of what I know so far:
1.Most of the time I can trip the dock pedastal breaker (20 amp with GFCI) with all boat branch circuits turned off. Most times when I turn on the main breaker in the boat the GFCI trips instantly, so this is not an ampacity problem. I'm convinced it is a ground fault problem, most probably somewhere on my boat (at least that's the assumption I'm working on at this point.)
2. The marina owner changed out the breaker on the power pedestal with a new 20 amp GFCI type breaker and the problem persisted, so I don't think it is a defective breaker.
4. I plugged in to my neighbors' docks GFCI power pedestal. I was able to turn on my main breaker and run a fan for about 20 minutes before it tripped the breaker. I did this several times and it repeated. Seems like this particular GFCI breaker may be a little less sensitive.
5 At one point when I was chasing this I was able to turn on the branch circuit breakers on my boat one by one. The breakers for the A/C, battery charger, port outlets and starboard outlets would trip the pedestal GFCI breaker instantly. A few of the other circuits would not trip it.
6. I used an almost new cord from a friend and had the same problem. At this point I have ruled out the power cord.
7. I have inspected both sides of the inlet connector on the side of the boat. It looks OK. I don't see any evidence of heat or arcing, the connections are tight etc.
As the "new kid on the block" I talked to a few of the other boaters who have been there a long time. Apparently this nuisance tripping has been an ongoing problem.
Since I got home yesterday I have done some research on the internet. There seems to be quite a lot of information out there about this situation in marinas. Some of the information is conflicting which is not surprising.
I read several places that it is difficult for even a properly wired boat with multiple circuits to not exceed the 5ma ground fault leakage that is the trip point for these breakers. To prevent nuisance trips but still provide adequate protection new boats are required to have an ELCI (Equipment leakage circuit interrupter) which protects the entire boat but is set to trip at 30 ma.
Any suggestions on a procedure for determinng the source(s) of this problem?
