- Mar 5, 2001
- 3655
- 1,800
Just a tad more of an explanation:
KO - Kills Odors - is strictly a holding tank additive.
However, it has been discovered (after the fact) that it can be used for other onboard applications as well, such as on pet "accidents" by spraying full-strength on the spot after having cleaned it up. Just spray it on and leave it there - let it dry. KO can also be used on musty pillows and cushions, but it must be sprayed on full strength enough to saturate all the way to the center of the padding. Then set it out in the sun and let it dry.
CP - Cleans Potties - was intended to be a toilet bowl cleaner only.
But it can also be used to clean drains and sumps. If given enough time, it will dissolve soap scum and hair that tend to clog drains and build up in shower sumps. Once a month or so, put a healthy squirt (1-2 oz.) into the sink or shower drain the last thing at night, before retiring, so it will have time to work overnight.
They are compatible with each another, but each has its own particular application (they can't be interchanged). Other toilet cleaners, deodorants, etc., may not be compatible with KO - they may kill the live agent in the KO, rendering it useless. So be careful what you use together with what - you may not get the result you'd hoped for!
