Yes I've used pretty much all the rechargeable softener/filters like and including the Water Mark. They work well as softeners and particle filters when you use a particle pre-filter. But you can save money by buying the same type tank softener that is in the Water Mark unit online or sometimes at a Home Depot.
They tout these softeners/filters as "spot free". But that really isn't true. They help with water spots. But for rinse down water to be truly spot free you have to have significantly knocked down the dissolved solids in it. And the only realistic way to do that is with an RO machine. Either from an on board salt to fresh RO machine or a fresh to fresh RO machine like the Spot Zero machine that a lot of large yachts are starting to use. http://www.spotzerowater.com/products.html?view=tovar&id=2
Yeah, slightly different animal compared to a simple sediment filter. Seems to me one of the 2-3 common brands actually is SpotFree or something similar...
Still, one of those augmented with a 1-micron pre-filter probably would at least help a bit more. Might depend on whether the goal is good tasting potable drinking water, or "spot-reduced" washdown water, or both.
(I see on one of the WaterMark links that the optional pre- and post-filters seem to be the smaller diamater household size, not the functional equilavalent of Culligan's "Big Blue" -- or Pentek's equivalent -- filter housings as available from filtersfast dot.com)
But that's all beginning to sound like a plumbing project
-Chris
