Homeport and name have to be on the stern of the boat. The requirements for the number are, in my opinion archaic; they say it has to be etched or carved into a bulkhead or other spot where it can’t be easily removed. This worked well in the old days when boats were made of wood. What I and others have done when there isn’t any wood that you want to carve into is to use stencil numbers of the correct height, 3 inches I think, and apply them somewhere in the engine room and then coat them with several layers of clear epoxy or fiberglass. The key is that it would make a mark if it was removed. The numbers don’t need to be obviously visible.
I've done what Harlen suggests above, I took the black letter/numbers that you would use on the hullside, found a conspicuous spot to put the document# on, then painted a few coats of West epoxy over all of them.
If you can't leave it to simple and cheap, I engraved the numbers in a piece of Aluminum plate and mounted it to my engine room wall...just follow the guidelines of the Coast Guard rules for number and letter size...
I realize not everyone has access to this type of machinery, a machine shop might charge you 25-50 bucks for this... I wouldn't pay much more..just another way to skin a cat...
Harlen, I don't think the name and homeport have to be on the stern. I've seen documented vessels with the name on the sides of the flybridge and on the sides of the bow.
Thanks, Greg, for that correction. For recreational vessels, the name and hailing port may be on any part of the hull but they must appear together. Commercial vessels are required to have both on the stern and on each bow.
Also on outboard powered boats and some sailboats, it is often impossiable to put the name on the stern. Name and Hailing port must be at least 4" high, easily legiable letters. There is also a requirement to put "NO" before the documented numbers. I put Doc. NO. the numbers, with the 3" vinly letters, and cover with 3/4oz (virtually clear) glass cloth, and epoxy.
