Does ANYBODY know......
mannmade
...how to remove the TV antennae on top of a radar arch? My boat is being picked up tomorrow morning (Wednesday/18) and I need to get this thing off. It's the standard white antennae, oblong pedastal with a circular 2 piece top...it seems like the top pieces come apart but while the edges give, something seems to be holding the center. Any suggestions will be appreciated...so long as they appear in the next 6-8 hours!
Thanks in advance.....George
they unscrew just like a vhf antenna,,,, then you need to remove the post if height is an issue or just leave it if the arch is coming down. undo the cable tv wire first.
The arch is staying up, there is enough clearance but everything mounted has to come down. So you are saying the top piece spins off? Hadn't tried to move it in that manner, thanks.
MANMADE,
The antenna has a small circle on top that turns 1/4 turn to remove. Be careful not to loose the spring inside. Once that comes off, there is a stainless steel allen head screw that mounts the antenna to the bracket. Cable should screw off from the bottom.
