does this make sense??
tboss
I have been pondering the idea of installing heat sending units and gauges on my risers and manafolds. I have a guage to moniter the engine heat but thought it might be beneficial to monitor the risers and manafolds also. If this is a good idea where can I purchase the senders and gauges. tks Terry------tboss PS I am also installing a low oil alarm on my engine also The ehgine is a mercruser GM 350 260 block
Risers contain a mix of water and exhaust gas, manifolds are pure exhaust gases. Your engine temp gauge is adequate since it's measuring the approximate temp of the water jacket. I sure as hell wouldn't tap into the manifolds/risers!
Some have used "normally open" thermal snap-switches (as used in dryers for example) epoxied or hose clamped to the risers. Just pick an appropriate heat spec for closing the circuit and you can have them activate a light or alarm at the helm. I think newer Crusaders, like '04 or '05 on, have riser castings that accommodate threaded heat sensors or switches, not sure which. Wish I could have waited a year for repower back in '03, 'cause that is a great idea for early warning that water flow is lacking. Much faster than engine coolant alarm or gauge, I believe.
How abt it folks does boatfix carry these snap ther. devices if not I bet it wld ba a good idea to start carring them. I wld purchase two of them if they were avail. tks for the info terry-----tboss
does your car have a temp sending unit in the exhaust? No....Why? Because there is no reason. same with your boat engine. There will not be an exordinate amount in difference of temp. from engine to exhaust manifolds. Instead, if you don't trust your dash panel...install another temp sending unit in the engine w/ gauge that is in the engine compartment taht is easily viewable.
