I did the loop clockwise. There can be an advantage as going against the current gives you more control. However it really does not matter as you will be going against the current at several points either way. The Tenn Tom is the better way as opposed to the Mississippi however many will find it as a challenge and just as interesting. The controling height is a bridge on the Chicago ship canal at 19'1". It can be even higher during low water times or whenever the water control people need to lower the level for expected heavy rains. The best way to avoid any problems is to have a boat that will clear all obstacles. Extending the loop to include The Trent Severn, the Rediou, Ottawa River and the Thousand island area of the St Lawrence River will make it an even better trip. Canada is great. Take the time to enjoy the sights. At the cost of fuel rushing through it will only cost money with little enjoyment. You should have enough fuel aboard to go at least 250 to 300 miles without a fill. There are a couple of areas you will need to make special arrangements for a truck to meet if you cannot. I believe the best of the trip was the interesting boaters we met along the way. Many have become long time friends.
