So far so good thanks to the advice and tips on the board. I've fogged the engine, changed the oil, drained all the water lines to the engine, manifolds, etc. For draining the outdrive, I pulled the boat to our culvert and dropped the drive all the way down. Is there anything else I should do?
I can see the water intake line from the drive to the transom and the line then from the transom to the engie, but it is very difficult to reach but I would think the water would have drained from this line when the drive was down and when I removed the lines on the front of the engine. Any thoughts or recommendations?
