My choice was limited to either trail it, or dry stack it.
I single hand the boat almost all of the time, and singlehand launching of a 27'er is somewhat daunting. ( Oh, I can do it, but I do NOT look forward to it. )
For $230 mo, payable yearly, I had a launch point 2 miles from my house, and access to the boat within 15 min from 8am to 5pm, 50 weeks of the year. At the end of the day, it was similar to valet parking: dock, leave the keys aboard, but turn off the bat switches, then walk about 60 ft to the car and go home. "Launching" was roughly the equivalent. There were about 15 temporary slips, plus fuel dock for the aprox 300 boats stored. ( This was usually enough. Fishing tourneys usually resulted in a fair amount of doubling up at the dock ). Late arrival menat using a slip, or docking in the pick-up area after closing. Early launch required some phone setup, and day before launch to a temp slip.
There was a "common" area, for the needed discussing of boating, fishing, and natural beauties.
Overall, much better than trailing, with about the same overall maintenance as trailing, and nearly as nice as a slip. A slip is nicer, but requires more maintenance, and apparently, usually, less security. In my case, the dry stack owner lived on site, and used a huge .50 cal black powder musket for dealing with trespassers ( quite effective! ). I am sure the details vary from facility to facility. YMMV.
---edit---
bobh mentioned damage from operations.
Yes. Boats do get damaged from operations. Notably, trim-tabs left in the down position, sometimes a poorly positioned transom mount transducer, and in my case, the head thru hull inlet strainer. On the other hand, it is necessary to understand the number of launch/pick up cycles. Do anything enough times, and something is bound to occur. I found the few problems encountered to be "within limits" when compared to trailing, and trailer maintenance. ( Not to mention the hazards of the road, and what might occur while stored in my back yard! ) In general, most issues were handled in a gentlemanly fashion, usually at cost, sometimes free, sometimes at the owner's expense, depending on who suffered "brain fade". Handle a boat often enough and it will get scratched and bumped. For the most part, I'd say that dry stack storage might be slightly higher than trailing the boat, but by a small margin, and since you use the boat -much- more, it might appear to be greater, but in actuality, it isn't.
