myoldboat2
- Jun 3, 2007
- 26606
- 135
Hello -
I have a 1970's Mercruiser 140 hp with a Mercruiser I (or maybe I-R) outdrive. After starting for the frist time since winterization last fall, the drive wouldn't shift into forward or reverse, there was a thumping noise from the rear of the engine, and the engine temp started climbing. I was able to determine that nothing in the outdrive was turning. By watching the splined shaft that connects the outdrive U-joint to the engine coupler, I could see that it was basically not turning--just erratic movement, maybe turning 3/4 turn in 30 seconds. I removed the outdrive. The U-joint and splined shaft look OK. The outdrive seems to work fine in forward and reverse when I turn the U-joint by hand. When I run the engine with the outdrive off, it runs great, and there is no longer any thumping noise.
Do you think the engine coupler has failed? Or could it be something else, as scary as the end of the crankshaft breaking? Do I need to pull the engine to even be able to inspect the coupler?
Also, does it look like the splined shaft was inserted far enough into the coupler? Some of the splines were showing. I have read that the wrong combination of drive/bellhousing/transom can result in not enough spline engagement, but I'm not sure how far it should engage.
Thanks in advance for any advice you can offer.
My advice to you would be to stop posting garbage links. I'll be too happy to just erase anything you might have to say if you don't.
