Ok, the engine cover on my I/O needs to be repaired/replaced. I started looking around to find a fibrglass from other boat so I can use it on my even if I had to do some mods to it, but it is worthless. Nothing that will match and anything that matches is all crappy looking. So, I'm going to to a new one for it.
These are the materials I'm thinking about.
1. Pressure threated 3/8 plywood
2. Plastic Water Ressitant Sheet (sell at Lowes)
3. Resine
4. Poly 2-part Paint
5. Insulation
1. Make the box out the plywood with SS screws
2. Cover the whole box with resine and let it dry
3. Cover the box with the plastic sheet and of course cut it to fit.
4. Paint inside and woden exposed sides with poly paint.
5. Cut holes for the 4 cup holders
6. Install insulation material inside the cover (dunno what to use for this)
7. Install on boat.
Any better ideas? Thank you so much everyone.
3. Resine
5. Insulation
7. Install on boat.
