- Feb 26, 2006
- 20354
- 1,075
So I finally lifted the engine out yesterday and it is in the garage on the stand. Will start the teardown and rebuild once the weather turns wet and cold. So now it is time for the planning stage on what to do, and what to make better, thus the purpose in the post.
Engine is a 1989 mercruiser 7.4ltr (454) carbed with a Bravo I out drive. Engine has 164 hours on it. If you had the oportunity to not only rebuild but upgrade it what would you do? Here is what I am concidering:
Change out 4brl carb to 4brl TBI.
Upgrade cam to a slightly more agressive cam but not so much it makes it lope.
New distributer and ignition system.
Replace pistons, not sure on what to replace them with yet.
All bearings, not sure on manuf. yet.
Oil pump
Timing gear set
Of course all seals and gaskets
New starter
New alternator
All new sending units, and figure out why the low oil pressure shut down did not work
Check all wiring
Replace all external bolts to either brass or stainless.
Might replace raw water pump to newer style
All hoses and lines
Send heads to head shop for full rebuild and facing
Send block to block shop for facing, boring is still to be determined but I doubt it with as few hours it has.
Replace all cup plugs with brass, found a few that are carbon steel
Cap off mechanical fuel pump and replace with external electric fuel pump, still a bit iffy on this as I am not a fan of electric pumps in a boat.
So there is the short list, I am open for suggestions, recomendations, etc.........D.........
Oil pump
Timing gear set
New starter
New alternator
Check all wiring
All hoses and lines
