Engine RPM drops under load
stovey
I need help? My port engine which is a 1989 4.3 V6 OMC King Cobra, After it has been running for about ten minutes or less I lose power, and the RPM drop to 0. I put the drive in neutral and it runs fine. As soon as it is under load the RPM's go up a bit and then drop to 0. I changed the Water fuel seperators. Could it be a coil, or the electric assist module????Any help would be appreciated.
Thanks in Advance......
