Last fall when I was trying to winterize an engine before hauling, when I pulled off the hose from the closed raw water sea cock, there was sea water leaking past the sea cock so I re connected the hose and winterized the engine while on blocks.
I planned on replacing the valve but today I found that the handle, to close the valve was loose and rotated about 10 degrees before applying torque and engaging the stem. It appears that the stop on the valve is preventing full rotation/closure probably due to wear/deformation after 15 years of operation.
I could not remove the handle for inspection since I did not have the right wrench on board.
I wanted to see if the problem was due to local deformation of the slot on the stainless steel handle or the portion on the stem that the handle engages with.
I was wondering if anyone has seen this problem since if it is the handle possibly I could get a new one. I suspect the deformation is on the stem side since it is probably softer metal, and repair not easy.
Comments appreciated.
