- Jul 12, 2007
- 27413
- 1,164
Sometimes you luck out. I pulled all the plugs on the port engine; the cylinders are emmpty. It's not hydrolocked. The starter relay or the starter itself is bad! I put the plugs back in and spent some time cleaning the cockpit from of the dirt, oil, and stains I left while working on the engines. Sometime over the winter I'll pull the starter relay and the starter and check which one needs replacement. Luckily this starter is actually easy to pull; it's right on top. That's probably the easiest part to pull on this entire engine. For now, I'm going to take a shower and relax a bit.
By the way, the engines are fresh-water cooled engines with auto antifreeze mixture running through the blocks and heads. The only sections which get seawater are the exhaust systems and the heat exchangers. There never was any seawater in the blocks or heads. I'm still thinking that the exhaust manifolds may have small cracks in them. I may pull all four again over the winter and have them tested for leaks. I don't want to begin next season with the same problems I had this season. We were seriously considering selling the boat because my wife is retiring in two weeks and we may be moving. The expense of the boat may be more than we can carry. However, my wife is now leaning towards keeping the boat because we'll have more time to use it now that she won't be working. We'll see what happens in the spring.
Meanwhile, I just want to wish you all a Merry Christmas, Happy Chanukah, and a healthy and happy New Year. Hy
