If the instruments are working you have power as far as the ignition switch. That pretty much leaves only the start circuit. This would be the key switch, the neutral switch, the relay if you have one, the starter solenoid and the associated wiring. Check all connections in those areas and see if anything is loose, damaged or corroded. Also check the big ground lead from the engine to the battery.
If the ignition switch is exposed to the weather it is suspect; try jumping from the "B" terminal to the "S" terminal with a short wire. If the engine cranks the switch needs to be replaced.
On some installations (can't speak for yours) the neutral switch can come loose and even though it's good it's not getting actuated. Check for this when you're checking your connections.
