Engine
Sails, oars, paddles, pedals, electric... Lots of options out there, for the smaller boats anyway.
Bear in mind we've only had gas or diesel engines for the past century. Before that....
Who knows what the future will bring? A few months ago someone crossed the Atlantic in a Solar-electric boat.
Neither green, nor yellow...
As mentioned before it depends of the boat (size, weight) and the type of boating you do. I have gas but would love to have diesel...
The 1983 diesel in my Albin is red (because of the rust). Still starts on the first crank, runs like a top and uses a half gal per hour of fuel at cruise speed.
I just repowered and stayed with Gas. Now I wish I ould have spent the extra money and went with diesel. The gas engines move my boat easily but they burn a lot of fuel at cruise and close to WOT. Because I spend most of my time either on the hook or at the dock the fuel costs don't hurt me. Where I would get hurt is in the resale value, and I have no near term plans to sell the boat.
I like this poll it's not "stupid". Robert weren't you the one that said "there are no stupid questions"?
Regards Bill
Take care. Bill
It certainly depends on the size of the boat and the use it is going to get. It also depends how deep your pockets are if you want diesel for a smaller boat that gas would be fine for.
Forget about the fuel savings, IMHO, it should not be a consideration for the follwing reasons. First off is the additional cost to upgrade to diesel, second is how many hours you put on your boat, third is the cost for maintenence, forth is how long will you own this boat before you buy another.
I have 8.1 Crusader motors (385 hp each) in my boat, the 40to 60k upgrade to diesel just put me over the edge on what I wanted to spend(it was not so much the money but I felt it was a rip off) My boat is 19k dry and no gear, with fuel,water, gear and people I would think I would be close to 24k in weight. If I was to buy the 42c or larger then there is no choice, diesel is the way to go.
So in answer to your question:
If the boat is small, 38 feet or less, you do not need to have diesel.
If you put little hours on your boat, then you do not want diesel, diesel motors like to be run and run hard.
If you want a bigger heavier boat and just put around with it, you do not need to have diesel.
If you want a bigger heavier boat and want to take long trips and really want to use the hell out of it then you want diesel.
If money is not a consideration and you will use the boat then diesel would be my choice for any size boat.
Off the top of my head:
GAS
1. more expensive per gallon to buy
2. The boat is cheaper to buy.
3. Cheaper to repair.
4. More dangerous the diesel.
5. Less GPH
6. Cleaner running then old diesels.
DIESEL
1. Costs less per gallon.
2. Boat costs more to purchase.
3. A bit safer then gas.
4. The diesel smell/smoke (older ones)
5. Better GPH
6. Cost more to repair.
7. The engines last a lot longer before rebuilds.
If your not going to put 400 hrs or so per season on the boat get gas. You can put a lot of gas in a boat for that extra 60-100k your going to pay for diesels.(big,new boat)
If your going to use it for long trips or all day/every day usage get diesel.
If you rich and money is no object, what the hell, go for the diesel, you'll be the envy of all your friends.
