I am ready to laminate a newly cut floor panel and need some advice. I've read on other posts to thin the epoxy with alcohol for the first couple coats to improve penetration. Then straight epoxy on the last coat. But do I add any hardener to the epoxy at all, or go without? The Bondo brand resin I bought says work time is about 10 minutes before the hardener sets up. That might not be enough time to finish brushing the entire board, and this stuff is too pricey to waste. If I don't use any hardener I'm not sure the epoxy will cure at all. What do I need to do?
