epoxy
ALKA2710
I had to remove my windlass for repairs and noticed that the holes that were cut out for the installation have exposed wood. There is a gasket that sits inbetween the windlass and the fiberglass but I wanted to put something on the wood to protect it further. What kind of epoxy or other material would be good?
Al
I've sealed holes with 5200. seems to work well. The only drawback is it won't be coming off but doesn't sound like that's a problem here. Was this a builder installed option or added on later?
ideally, whenever a hole is drilled in a cored deck, you need remove some of the wood core and fill it with thickened epoxy. Much better than sealand or relying on the gesket. doesnt' take too long, worth doing right.
At a minimum, get some unthickened epoxy and a small brush (small glue brushes are ideal) and paint it on the exposed wood. As it soaks in, paint a little more (without creating a mess). Better is to do as Pascal notes. Remove a little wood as a buffer, paint with a little unthickened and let that soak in, then fill with thick epoxy, then re-drill the original hole size through the epoxy sealing the wood. You can then re-install with the gasket or a sealant/adhesive such as 5200 or 4200. 5200 is still useful/best for a windless as the adhesive property actually improves the mounting by bolstering the mechanical fasteners with its adhesive property.
You asked what kind of epoxy. Any of the name brands work very well, West, System Three, etc... I like buying a product that I can mix in thickeners so I can use it unthickened or thick as I want it instead of buying more expensive pre-mixed products that I can't customize as easily like marine tex (though they are sometimes convenient). Frankly, they all seem to work rather well. Procedure is more important determination that outcome than is the brand.
There is a very good reason to remove some of the core and replace this with epoxy. The core is subject to rot, if there is water intrustion (assuming it is a wooden core). You can use a Dremel tool and remove about 1/4" of the core all around the hole--or you can use a coat hanger checked in a drill, and bent at a right angle, --1/4 to 1/2" is a good amount to remove.
The other reason to remove the core, and replace it with epoxy, is that core can compress, especially balsa, and foams--and less with plywood. If you had solid epoxy, it will not compress and distort the deck.
I use Cabosil (Fumed silica) and high density filler with West Systems epoxy. I have filled every hole in the deck, and then redrilled or smoothed it--so there will be no probelm. This year, I purchased a boat only 3 years old, which had the cockpit floor completely destroyed by not sealling a cored deck. (got it cheap--and the factory paid for the repair). We had to completely replace the deck--and used Nadicore--which is a synthetic--and even that we epoxyed the holes and hatches cut outs--for the compressive strength.
Thanks for the replys. This is a 2007 boat and I was surprised there was no protection. What is the difference between thickend and unthickend epoxy? Is the unthickened without the hardener?
Al
Hey Al
Unthickened epoxy is just plain resin and hardener. Various brands use different resin to thickener ratios depending on their chemistry. Thickened epoxies (thixotropic) are the same with additives to make them thicker such as mentioned silica but can also be common things such as wood flour, micro balons or talc or milled fibers. There are epoxy adhesives which are already forumlated to be used in these types of applications and already contain fillers. For a quick and less messy job look up System Three Gelmagic. It comes in a tube and is dispensed just like caulking from a squeeze gun. No muss and no fuss.
The perfect tool to use to remove coring is a small allen head wrench on a variable speed drill. It's a perfect 90 degree angle and strong enough to do the job.
Jonathan
I used a bent nail on my drill to hollow out my core. I also put tape on the underside of the deck to keep my unthickened epoxy from dripping out. I figured unthickened epoxy would have a better chance of soaking into the core. After it dried, I redrilled my screw holes.
Al, sorry for not explaining about "unthickened" epoxy. It's actually very very simple. Most epoxy's are two part which you mix according to the mfg's instructions (often 1:1, but read the label). You MUST mix the right proportions. This is not like other resins where mixing more of the hardener makes it cure faster.
Most epoxy's come in the consistency somewhere between apple juice or syrup. If you warm them up gently you can make them just a little thinner (but be careful they will kick off quicker if you do and will need to mix in very small batches). Why thin? Because it soaks in better. Why not thin? Because it won't stay where you put it. Because it has a bad habit of making a real mess!
So, to solve the problems of regular plain ol runny epoxy, you can mix in compatible substances that will thicken up the mix. A few years ago I bought a HUGE bag of colloidal silica (cabosil). It is the consistency of the finest powder you can imagine. Here is how it works, very simple. Mix up your regular epoxy (following the mfg's proportions of parts a/b). Always make sure you thoroughly mix. Scrape the sides of the container and the corners of the bottom of your container. Once you have it mixed, throw in a handful of compatible thickener such as the cabosil (there are many others). Stir! You will get a thicker consistency. Want it thicker? Throw some more in. The two most common mixtures you will work with all the time are unthickened epoxy and something about the consistency of peanut butter. The peanut butter stays where you put it. You can even shape it a little.
Here's the problem with the thick stuff. It doesn't soak very well. So, if you just smooge some thick stuff in a hole, it will actually bond, but often you find you can apply some decent pressure and "pop" out it comes again. So, here's the secret. Mix up your untickened epoxy. Take it straight to your work and paint it on the surface and let it soak in, you don't need to apply to excess. Take your cup of epoxy and now throw in the thickener ad mix it up to peanut butter. If you work quickly enough you will have plenty of time before it starts to kick off. Work in small batches. By now, your unthickened has soaked in, so now apply your peanut butter mixture to the work. The peanut butter mix will bond chemically to the initial thin painting and now you have a bond that is soaked into the work and stays where you put it.
Make sense?
There is a whole world of options as to what to use to thicken. Some are easier to sand than others. Some add strength (fibers), etc.. Don't get to worried. For most stuff you can keep a basic thickener like cabosil on hand and use for most jobs. In a pinch you can use sawdust (wood flour) or even wheat flour (it actually works). Not every powdery substance will work so only choose things that you know work with epoxy.
As mentioned, you can buy epoxy's that already have thickeners mixed in. They are convenient, but you can't make a thick epoxy thin. Okay, well actually you can, but this goes beyond basics and best that if you don't do this all the time to stay away from that. That's why I like to buy your basic off the shelf expoxy (thin) and a bag of thickening powder of some sort. I can mix anything I need then easily and quickly to suit the job.
bp
ROT DR.
awesome stuff. easy to use -turns wood to plastic.
or: drill the wholes a bit bigger then fill completely with resin/glass and then redrill the proper size for the fastener.
Holy Cow BP. Thanks for that response. I have to say that I really appreciate the time that you put in to answer that question. This forum has the best members.
Al
Yeah Brett...excellent discription. Couldn't have done better myself.[:I]
I buy the fumed silica by the 20 lb bag, too.:D
...another way to remove some core material is to cut the top layer of fiberglass out with a hole saw to remove a larger area of core material. Treat as Brett said and glue the disk of fiberglass back. It may look a little sloppier but you'll end up with a stronger mounting area.
ROT DR.
check out the web site. simple. easy. works awesome. penatrates better then anything going.
i have used quarts upon quarts on many differant types of projects...boat, home, etc.
did i mention easy? oh...and simple?
Rot Dr is the same as Smith's CPES and easier/cheaper to find. Good stuff.
If you use Rot Dr., make sure you have either great ventilation or some kind of respirator. That is some nasty stuff. You can see the fumes it generates.
Also, when you remove some of the core material, remember to scrape away any core material that sticks to the inside of the laminates. I would also sand the inside of both laminate surfaces with 80 grit paper and clean well with acetone before starting the aforementioned procedure. The epoxy to laminate bond is a mechanical one and you need a perfectly clean and roughened surface.
