Evinrude - no spark
pauld
I have a 1990 OMC Seadrive (Evinrude) 225 that has no spark.
When I first tried to start it this season I was getting a little fire and had it started for a minute or two but couldn't keep it running. I was thinking bad fuel but I have twin engines and I had no problem with the other engine. I ran most of the gas out of the tank on the other engine and added fresh gas and changed the water/fuel seperator. Both engines use the same seperator.
When I checked for spark at the plugs I had one plug not firing on the port side (top plug) and the middle plug was not firing on the starboard side. I moved wires and plugs around to rule them out (I now have new wires and new plugs installed). After messing with it for a while I had no spark in any port plug but all starboard plugs were firing. I switched the leads on the stator/charging coils and the problem stayed on the port side so I figured it was the powerpack. Bought a new powerpack from Boatfix and installed it. Now I have no spark at any plug. I did remove the stator thinking that was the problem until I found a troubleshooting guide that recommended switching the leads to see if it was the stator or the powerpack.
Any suggestions? Is there a way to test the powerpack and stator?
Paul
