floor material
tfret
I can already see I'm going to have to replace some of the floor in the 84 Dixie I just bought. I'm new to this and a little overwhelmed at all the floor material terms and options. What's the best material to use, what type of prep does it need, and where do I get it?
Marine grade plywood. Ask at a ( real, not big box retailer ) lumber yard.
Actually, for an interior deck, exterior grade will work.
You will need to coat the wood ( paint, f-glass, etc )
dunno if u already did ur floor repair but let me know if this is a open boat. I did the regular playwood, covered in resin and fiberglass on the bottom and on top I painted the whole floor with Rhino (same thing they use on pickup trucks) came out great.
the main difference between exterior & marine is that marine has no internal voids. otherwise same glue. this is right from the mfg.
as long as you prep the plywood w/resin, seal all of the screw holes, it should work. if you are going to gel-coat over the top you should put down 2 layers of heavy mat covered by one layer of woven. this is what the fiberglass pro put down over the plywood on my floor. then he put two coats of gel.
good luck
Just replaced a balsa cored floor in a cockpit with Nida-core one inch thick. The Nida core is hex cell, poly prop, with mat on each side and bonds well with polyester or epoxy resins. We saved the old bottom layer of mat and 18oz woving roving. The new top was one layer of 3/4oz mat, and 12 oz biaxial cloth. The Nida-core cost $70 for 7 x 4 foot piece. Weight about several pounds (much less than plywood)--never have water intrusio or rot, strong and easy to use to build the new floor. Final finish was waxed gel coat, with extra cabosil added and rolled with a short nap roller to give a nice non side surface.
Okay, your using some terminology I haven't learned yet..but for now let me stick to the basic material question here. So, what exactly is Nida? Is it completely synthetic? I'd like to get away from wood all together if I can do it without breaking the bank.
>>>"main difference between exterior & marine is that marine has no internal voids. otherwise same glue. this is right from the mfg."
You are absolutely right. Not many people know that. I just replace/rebuilt my transmission last year and the easiest way to get it was to cut a hole in the deck. The 24 year old plywood looked brand new. when i had the boat built the builder resin coated the plywood before it was installed and glassed over. It is 2 layers of 3/4 and it is still one of the best decks I've seen to this day. Them Maine builders know how to build a boat and wouldn't hesitate to use this method.
Link about Nida-core. It is a polypropylene honeycomb, formed into a sheet adn used as a core material. By itseilf, it has little strictural value. When sandwiched between two layers of something such as fiberglas you form a strong, lightweight panel. And while I -love- using honeycomb materials, it is not for the faint of heart. And in use it requires special handling when attaching with screws or through bolting.
Unless you require the extreme performance of an aircraft type product, I would not recommend it. Marine grade plywood is an excellent product, relatively easy to get and use, and performs well.
And, yes, you can use standard exterior grade plywood. It can ( and will ) contain voids which can cause various types of problems, should not be used as a core for below waterline structures. For decks and above waterline walls/panels it is acceptable. But since marine grade is better, and not very much more $$, I would recommend marine grade for all boat usage. ( Just my $0.02 ).
I'm not sure what you mean by exterior plywood / voids may cause some problems? If you have no intensions of resin coating all edges of a exterior plywood for a deck I would have to agree. I worked/helped build 2 glass covered aplywood boats back in the 70s and one of those boats is still around. We used exterior ply over oak frames. This may outlast unresined marine plywood now that I think about it.
You treat either plywood the exactly same way, and imho, you should always coat with epoxy resin. The problem with voids is that there is a) a slight possibility of local increased weakness to puncture, and b) if water gains access to the interior of the panel( via, say, an improperly installed screw or bolt ) the water can more easily travel to a large area, rather than remaining localized. Exterior grade is a good deck material ( and it should be epoxy and hopefully, at least one thin layer of f-glass, coated ). Marine plywood is better, due to the lack of voids. And note that the problem is not necessarily with the edge ( which always be sealed, regardless of type ) but with the results of "beneficial penetration". There is very little difference is price of a project due to the choice of marine vs exterior grade. The cost of any such project is mostly labor. So save yourself a problem and use the marine grade. In fact, it is for this exact "traveling water" issue that marine panels are made. The glues and assembly methods are the same.
BTW: my garage currently has exterior grade doors, and due to my having fired the contractor, it has been unpainted for quite awhile. And, as we almost certainly both expect, these panels are rapidly deteriorating. Marine grade would look the same. All of these panels need to be properly edge sealed and coated.
