Flushing Oil
gaboy
Float for bilge pump failed and water got over my oil pan. I flushed with 2 oil changes and still notice a little small amount of milky on stick. Is there something else I can add to remove excess water left over? Someone told me to use diesel fuel????? What about WD40?
Continue to change the oil and filter with cheap oil and cheap filters until it runs clear. Run it for longer periods of time between changes. Once you can get over 15 minutes without traces of water, put the better oil and filter on. Do not add diesel fuel,WD-40, or any other additive. You also need to check your tranny if inboard.
Check tranny, for ????????? for water in oil???? Mercruiser 350/260hp inboard.
Yes, check the trans for water in the oil. Also wipe down everything that got wet with a WD-40 soaked paper towel.
There seems to be another problem with your engines--If the water got over the oil pan , how did it penetrate into the oil itself. There must be a leak somewhere around the oil pan and if so you probably need to find and repair it first.
I figured that the water got in at dip stick entrance. Could leaving the stern up while storing cause this. The oil was perfect until I moved the boat 30 miles for storage. The next day I checked the oil and found a slight milky on stick. The oil I found in the bottom of the bilge has no milky to it. Since the original flooding and changing the oil the engine has only been cranked once just to check the battery and cranking. I had muffs on with water and never got over 800 rpms for 5 mins. I was concerned that I had not removed all the water after the flooding.
Forgot to ask. How do you check the trans fluids? I thought the fluids were in the outdrive or is that what you are talking about? Is there an actual transmission?
You stated earlier you had an inboard. If you have an outdrive, you do not have an inboard. It's one or the other.
Wow, maybe my terms are backwards. I thought an inboard engine had an outdrive or sterndrive. I have a Mercruiser GM 350/260hp with an Alpha 1 drive. I found the oil leak yesterday, it was coming from a hydraulic cable connection. I have flushed the oil twice and will continue to monitor to see if I continue to find milky oil. The engine runs great and I just thought that the water got in when the bilge flooded a month ago and that some water was left behind after flushing oil after flooding.
Technically Stephen, it's not one or the other - it's both. I/O means inboard engine/outboard drive.
An inboard engine has a shaft running thru the bottom of the boat with a prop on the other end.
An Inboard/outboard (I/O) has an inboard engine (I) with an outdrive (O) like a Merc Alpha.
No SLW, it's one or the other. You either have an inboard, an I/O, an outboard, or jet drive. There are further varieties of each, like "pocket" or "tunnel" inboard, and many varieties of outdrives, but when I'm told a person has an inboard without further words, I assume inboard. Inboard to me means that the engine, V-drive, transmission, reduction gear, or whatever you want to call it is entirely inside the hull with only a shaft going through the hull. As such, a flooded bilge provides the risk of water entering an inboard transmission through the dipstick or vent.
This is just semantics, and yeah, without further words, "inboard" implies it's not attached to an outdrive. My point is that I/O, by it's very definition, IS both. It's an inboard ENGINE, outboard DRIVE. I/O.
If you're only seeing the milk on the dipstick it may just be condensation.
I found the oil leak yesterday, it was coming from a hydraulic cable connection."
And where is THAT connection?
Milky residue on the dipstick can also indicate a failed head gasket.
The brass connection fitting which connects cable to transom and works the trim. One cable is coming from trim motor and the other cable is the one I found and it would not stay tight. So, I purchased a new one and stopped that leak. This leak had nothing to do with milkiness in oil.
