For the first time...
In the know
in over 25 years of boating - I had an anchor I could not break free and had to unceremoniously cut it free.
Anchored off of Dutch Island, when we went to leave I had a new crew memeber volunteer to lift the anchor - great. After a few minutes he looks back and says - "is it always this tough lifting an anchor?" I go up and man o man are we stuck.
We tried nine ways by Sunday to free this thing. At one point two guys from a nearby raft come over and volunteer to help. What the heck, throw some more ideas in the kitchen.
In the end all that happened is we shared some beverage and joked that we are tying a float to it because it is better than any mooring out there.
Time to go anchor shopping.
I have no clue as to where you were anchored. Was it too deep to dive on the anchor? ( or otherwise inappropriate )
What kind did you lose, and what kind are you intending to get?
Water Depth was 40 feet - SCUBA gear at home in basement.
Danforth Hi-tensile with 60' chain.
I have it marked and will be returning.
My guess is you snagged something - tree, pipe, etc. SCUBA time, and be prepared for extrication. A lift bag might be handy.
<<..."My guess is you snagged something - tree, pipe, etc. "....>>
In RI, it was more likely wedged between a couple huge rocks. You don't get much large scale debris stuff like trees, etc. up there.
Slide a loop of chain down the rodeo with another line attatched to the loop of chain. Pull 180 degrees from the way that the boat was lying when you were anchored. The chain will slide down the rode, chain and under the shank, pulling the opposite direction will pull the anchor out from the rocks/tree etc. There is the option to bouy the anchor, and go back and get the scuba gear--or be able to free dive to 40 feet, and slip the chain/line around the shank as with the chain from the surface.
I normally use a delta, so a dive to attach a float/retriever line to the fluke end would be my usual plan. 40 ft is a bit uncomfortable for me, however ( sans equipment... )
Bob's chain loop is a good trick.
I tried that Bob. The end result was the gentlemen that came over from the raft up tender came to a sudden and abrupt halt.
The odd thing is the boat is anchored at this anchorage at least twice a week and we have never had an issue with the anchor. I have also dived this anchorage +/- 15 times and can tell you the bottom is all mud.
Really can not wait to see what it is stuck in/on.
ITK,
It might be mud cover over rock/ledge rock. Dollars to donuts, you're hooked up to good 'ol New England bedrock or wedged between a couple big-ass glacial boulders. More likely the bedrock if you haven't seen boulders around there. It'll be interesting to find out when you get the answer. I used to anchor there a lot, but haven't actually seen the bottom (except in shallow water).
Good luck with it.
