fresh start with new electronics
Jamie 10017
If you were able to have a fresh start and refit your boat with all new electronics what would you install on a cruiser that you may take a overnight outing or maybe a fishing trip just looking for ideas and opinions . Things like radar ,sonar etc.
Radio/Hailer, Depth/Fishfinfer, GPS Every thing else is for Gadget Freaks (yes that includes radar) I stay at the dock when the weathers rough.
For the motor atleast 2 engine batteries , anything else runs off a house battery
2 VHF`s with separate good ant
minimum 3600 GPH bilge pumps, a hand pump/bailer
minimum 600 Ft of anchor line
a 2-3 ft radar reflector
compass
marine vhf
gps chartplotter
broadband radar ( "old style" is nice too, but close-in, in fog/dark, is priority )
a brief comment relating to radar reflector:
No question about it; a large radar reflector is nice. BUT a large one is only a good thing when deployed. A large one is likely NOT deployed while running.
I went and bought two "small" radar reflectors, assembled them and placed them in high, unused ( generally inaccessible ) places in the FB. Most fiberglass is radar invisible, so they worked just fine, all the time. When anchored/drift fishing, sure, deploy "the big one". But something that always provides a target seems to be a better thing. Also note that reflectors have strong and weak areas, so when using more than one, attempt to "aim" them in different orientations, which will tend to resolve the issue and always provide some return.
as for anchor, bilge pump etc, this is basic running gear, rather than part of the electronics/navigation suite. Yes, always have an appropriate anchor rig ( or two, three ), appropriate bilge pump capacity ( BIG ) plus manual equivalents.
While two mounted VHF radios are useful, on a limited budget ( money OR size/weight ), one fixed mount plus one HandHeld may serve you better.
This could evolve into a long list. But the above primary list ( more or less in order ) should be covered first.
---edit---
re: depthfinder
In this neck of the woods, water is always too shallow. Usually all a depth finder does is tell you that you are in fact, aground. Which in soft silt bottoms is not a particular worry except for water pump impellers and/or ecologists. In short, it was froo-froo rather than useful. And if you had more than six feet of water, it served little purpose. But is can be useful for fishing. So, you boat usage will determine the need for a depth finder. Charts and/or "local knowledge" generally have proven more useful ( to me ).
Compass!
2 VHF is preferable but you can get away with one. The antenna is more important than the brand of radio.
Depth/Fishfinder is really important. Depending on where you are and how familiar you are with your area, you can do a pretty good job of navigating with a depth/fish finder.
Of course, a chart plotter with the FF will get you home.
If you're out at night or in the fog, the radar along with a radar reflector may save your life.
And one of the most important things I can think of for night/fog is a chart plotter with a quick refresh rate. You'll only realize how important it is when you get in the situation of no visibility and close in to danger. You have to know your direction of travel. A slow chartplotter and even a slow compass can get you going in circles.
high water alarms in each bilge compartment
additional high mounted backup bilge pump in ER and at lowest point in boat at rest
Boat Wench
Compass (not necessarily electronic).
VHF radio, with DSC, and with hailer and auto-fog sounds.
Fishing implies Fishfinder (depthfinder) would be useful.
Chartplotter with GPS.
Autopilot.
If "overnight outings" means underway in dark (or fog), radar.
If all that's networked together, so much the better (for example, GPS info served to the DCS radio).
Lots of other "nice to have" (or nice to play with) stuff can give you a reason to spend more money, of course. For example, you might find AIS useful is you're in an area with big shipping or lots of tug traffic, etc.
-Chris
2 screens, both at least 10-12 inchs, GPS, plotter, fish finder, radar. 2 VHFs, EPIRB, towing insurance.
If your asking the manufacture I would highly recommend Garmin electronics using a NMEA2000 backbone.
