Fresh Water Counter Project - It Works !
Pilotpak
Hi,
Having had a few bad experiences with Fresh Water tank gauges on previous boats that didn't work, over the weekend I installed a Counter system to better keep track of how much fresh water I have actually used - and to my surprise it works just fine !
I purchased a miniature industrial water meter with a reed switch interface and a digital counter. The water meter was inserted in the 1/2 inch line after the boat's water pump, and the counter was mounted above my breaker panel.
Tested it out and it's 100% accurate, uneffected by boat list or movement, and as the counter is battery powered, I didn't need to play with the boat's electrical system.
Total cost was around $200
Wayne
2006 Larson 310
URL]
Hi Bill,
I got them from a small rural irrigation supply warehouse in country Australia, but they come from Gonars, Italy.
Check out www.bmeters.com ... they might have a re-seller in your area.
Item numbers are H7EC-N for the digital display and GSD5-R for the meter.
However, the readings are in Litres !
Wayne
p.s. I've just noticed that this company also has a color digital counter...now that would look cool !
