My fresh water system took a dump.
http://www.xylemflowcontrol.com/files/31765_43000-0869.pdf
Jabsco no longer makes the pump ( i did find a couple places on the internet that still have them though) Pump is around $800.00
Jabsco replacement for this is rally not a great replacement because the specs are different.
In other words, the pump I have now says it pumps 9 gallons a minute, and the replacement is 5 gallons a minute. PSI is the same.
Is PSI the force the water will come out of the faucet?
How concerned should I be about gallons per minute?? I don't know how that affects the system?
The boat I have has two heads each have a shower, sink and crapper. Galley has a sink, cockpit has a sink and outside shower. In also have a washer machine.
With that said would the GPM only be a concern if I was running all that stuff at the same time???
