Front window is leaking.
I have a 1980 Carver 28 with a flying bridge with medal frame front windows below the bridge. It looks like the window needs to be resealed. Has anyone taken off the front medal window and tried to reseal. Good size window I guess 3 feet by 3 feet or better to try to remove. I don't know what to expect or find. I'm thinking of loosing one side at a time and trying to put sealant under to stop the leaks. It looks like it is screwed to the fiberglass every 6 inches along the frame. The trick is to lift the window for the sealant and not bend the frame or crack the window. Suggestions?
