Fuel Additives
hamster
Hi everyone. As we get closer to launching our boats here in the NE, I was wondering if anyone adds a fuel additive, like carburetor or fuel injection cleaners, to the gas take before heading out for the first time.
If you use an additive like PRI-G it should have been in the fuel prior to lay up and nothing would be needed in the Spring.
Here's a topic that could go on for years....every case is different, but I am open to any and all comments.
As I have said in the past I have to haul my gas from the only local gas station in 5 gal. jugs. It is my only option.
The gas that is delivered to the island is a BIG question?????????????
I beleive that the supplier is either Shell or Chevron. There is nothing on the pumps as far as octane or ethanol... its gas and it burns.
My question is this. I am willing to buy and pay for any product that will protect my boat investment.
What are my options and what products will cover the most bases??
I have a separator fuel filter, but one batch of ethanol and I am toast.
Bahama Bob
Startron. I add it every time I put fuel in the boat.
The only fuel additive I have used that made a positive difference is Chevron Techron. I have not tried all of the others but of the ones I tried over the years this one was notable. It improved the performance on fuel injected and carbed motors. Rommer; I like kettle corn.
Startron is a lot about smoke and mirrors.....
Can anyone explain things like this on their website...
" One major change I noticed during the voyage was in the past on our normal runs we usually make 10
knots at 600 rpm, but after the treatment of the fuel, we increased to 10.8 almost 11 knots at the same
rpms."
Here ya go Ironworks...
Originally posted by rommer
Popcorn anyone?
Does Popcorn boost the Octane lever, or is it a stabilizer?...
Is an aftermarket brand OK, or do you recommend Orville Redinbauker?...
I have used Soltron for years. I do not know if it is the same product as Startron or not. I have witnessed gas and diesel engines that would not start, add Soltron to the tanks, wait 1/2 hour and the engines start. I also have friends that sware by this product. Check it out on the web.
Remember, that all addetives work better on particular fuel problems. All additives are different and all fuel problems different(stale, algie, water, etc.). The best thing is to try an addetive that addresses your particular problem.
Good luck, and happy sailing.
BABNCB
St. Martinville, La.
265 Regal
I added Snipe-oil additive to our sailboat.
We now get 14 knot speed from a 10 knot wind.
Thanks for the suggestions.....except for the popcorn...sorry Rommer. The marina where I keep my boat suggested I put in Stor N Start and Startron Gas Additive. They said they have been selling Startron for a few years and had no complaints. I followed their suggestion, added the required amount of both and ran the engine for a few minutes afterward before hauling it out for the winter. So I guess I'm in the same ballpark as some of you using Startron. Thanks again.
Joe
Joe
I put an extra 8 oz's of diesel fuel in my tank each fall and I've never had a problem starting my boat in the spring either. Works great! (Keep in mind I have a diesel boat)
Wow!!!
Where can I get some of that 40% from nothing stuff! Sounds great!
If your boat is running good, there is no reason to add anything to your tank if
you buy a good quality gas.
You will only need a good stabilizer when you fill up for your last tank before
putting her away for the winter.
We tried several different brands when we bought our current boat and none of
them made a difference in the way she runs or in the fuel economy. It is snake
oil if it says it will add mileage to your car or boat.
Thanks to the weather down here, we don't have to lay up for the winter, we just
put a heater in the engine room just before a front hits and we are good to go
when it warms up the next day.
FWIW - I'm not trashing all fuel additives. Fuel stabilizer added in the fall before a long layup is very important. Diesel biocides and octane boosters etc all have there place.
Adding things like Startron each time you fuel up is a big waste of money from a company that makes unprovable claims and then posts as testimonials things that are physically impossible to occur. Startron is 95%+ naphtha with less than .5% "enzymes", (Proprietary Organic Compounds)
Busy little bugs those enzymes.
It seems some people think additives are snake oil and others think there is some merit to them. Gas companies use additives in their gas. I believe they do it to keep fuel injectors clean. In the early years of fuel injections it was not uncommon for fuel injectors to get dirty. Dealerships would have to remove and clean/replace them. Over the past 10-15 years this has gone away. It might be because of the additives in todays fuel or it might be because today's injectors do not get dirty as in the past.
All my experience is anectdotal. Others at my marina who buy gas the same place I do (10% ethanol), have had problems with their fuel systems. Those of us who add Startron have not. Not scientific at all, but I'm not looking to write any papers, just trying to avoid problems with ethanol in the fuel.
Oil companies have to add additives to gas because plain gas will not last.
Some are better than others, but the difference is not very noticeable for
the short term.
Large oil companies spend a lot more time and money to get the formula's
correct. In my opinion, if you use a major oil companies gas, it will have
the right additives, for short term use. Not for storing all winter.
The smaller refining companies usually pay for other someone else to
formulate and manufacture there additives.
All work good, some better than others.
However, the E-10 crap throws a monkey wrench in things. We have yet to
have to worry about that issue so far.
