On my last boat, as per the instructions with my pump, I ran a wire from the + coil term ( purple ignition wire) to an oil pressure cutout switch, and then from the switch to the pump. It worked fine, but I didn’t love that the pump would not run until after the motor started. There were a few times I had to jump it to get the carb primed and motor started. that was a Facet pump, which drew only 1 amp.
i have not decided yet what I’m going to do with my current motor. For now I just have a wire running from the alternator ( purple ignition wire terminal) to the fuel pump. So the pump is running whenever the key is on. But the motor isn’t in the boat yet. I’ll most likely put in the oil pressure cutout before I drop the motor in. But with my 2 amp pump, I wasn’t planning on a relay or solenoid. From my understanding, the cutout switches are fine up to 5 amps, which is well above what my pump will ever draw. And my pump runs at about 7psi, which is a bit above what my carb wants, so my top concern now is whether or not to put a pressure regulator on. Holley says no, my carb guy says yes.
I still have the Mercruiser 30 amp relay from when this motor was mpi - i suppose that is an option as well.
86-865202T
