" it seems like there should be some general guidlines or ranges for engine types and sizes fuel useage at a given rpm" -- Portland
There is. It is however inaccurate, because each boat, it's condition ( engine and bottom ), the environment ( temp, humidity ), the seas ( waves, fresh/salt ) and one assumes, the attitude of Neptune or Poseidon all have an effect.
Here is how to -estimate- the usage ( gasoline ):
Take total HP and divide by 10. That is your Gallons per Hour, at Wide Open Throttle.
Take half of that number. That is your GPH at "cruise".
Now, combine the Gallons per hour, with the speed ( Miles per hour ) to get MPG. ( or kts to get NMpG )
Note that this is an ESTIMATE. You should -always- prove these numbers, for your boat, in an assortment of conditions, to get good info. Make your own chart, from your log book and/or testing.
Have you been collecting fuel usage data? That is your best source for info on what kind of range you will get.
