Fuel Stablilizer Thoughts
Holy Grail
Just curious, as we head into the "off-season", what people think good/ bad about using a fuel stabilizer through storage.
I've always topped off the tanks before storing, cause I've heard it's the right thing to do. Thinking about adding the fuel stabilizer too. Never done it before.
For the record, I've got twin 150 gallon tanks for gas engines.
Please share your thoughts about both topping off tanks and using the stabilizer... if so, which brand is best. Thanks.
Holy,
IMHO depends how long the boats on land for ... I think everyone kinda adds a stabilizer. Honestly dont know if there snake oil or not. IT cant hurt elts put it that way. I always have... Starton worked for me. I would suggest adding something.
I always add fuel stabilizer when laying up. Gasoline can turn gummy if stored without it. As to filling up before storing, I've heard arguments for and against. I prefer to lay up with as little fuel as possible in the tanks. I've read, and been told by a few sources that there just isn't enough air volume for water condensation to be a problem. So I just add fuel stabilizer for whatever I have left in the tank and put fresh fuel in in the spring. Never had a problem. Here's a good article on the subject.
http://www.yachtsurvey.com/myth_of_condensation_in_fuel_tanks.htm
I heard that if you store fuel (gas) for more than 90 days.....even though you use Startron or E-Zorb.......its a good idea to add some "octane boost" in the spring too.
Haven't tried it yet.........but I will.
Good points guys as usual. I am still doing my research. Hoping to head out tomorrow and check out those seals near the Jones Inlet. Should be fun. In the meantime, any additional info is appreciated!
This will be the first year that I did not top off my tanks; I was always a believer on doing this till recently. After extensive research I found a site that discussed modern day gas and gas of the 60s and 70s era. In a nut shell, gas today has a very short shelf life, this site said 30 days before the octane starts to go south. Funny thing, after I read that I remembered a friend of mine that owns a Mobil gas station telling me that when he renovated his station, Mobil would not let him sell the gas in his tanks because it would be sitting there for more than 30 days.
As far as water condensation, another site I visited explained the math of this and how much water could actually exist due to condensation. Based on my tanks (142 gallons each) with the worst conditions and the tanks bone dry, I could only see an ounce or two of water.
I left my tanks half full this year and will either add an octane booster or top them off next season with high test. I have that MPI fuel injection system in my boat, this system automatically adjusts the motors(timing) to run better if there is less octane than needed (my octane is 87). Reason I mention this is that you may not notice a difference in the spring because your motors are compensating for the lower octane. You will burn more fuel and I am not sure if it is bad for your motor.
If you have carburetors and run the boat with low octane you will here the motors ping and you will definitely be doing damage if you do not add an octane booster, top off with high test or retard your timing till you burn the gas off.
As far as fuel stabilizer, I still use it but have no other reason to tell you other than I always have. My understanding is it prevents the gas from gumming up.
PS.
If I have any problems next season I will be deleting this post.
I believe that also...........last year was my first year ever of NOT topping off the tanks for the winter...... and this season I had zero fuel problems. Although I do faithfully use Startron and E-Zorb...plus a little Marvel Mystery Oil occasionally.
Im storing this winter with 1/4 of a tank in both.....and will add octane boost with my spring high test fill-up.
Screw u guys...Im topping of my tanks .. and filling all the fuel cans I can find.... Tony went to bergen pt for fuel they stopped ordering super unleaded as its not selling . There next fuel delivery will raise there prices 40 cents a gallon.... x 350 gallons... FU my tanks get filled tomorrow....
So i nthe spring i get head start u gusy can pay 5 bucks a gallon first!!!!
I know some friend!
But i do agree with walter ... I always stored the boat with 1/2 tanks ... from another prespective I didnt want all the weight of full tanks...( u never know when a boat might FALL )
Can always count on Walter for a combination of humor and good advice. Thanks. I am going to talk to Mike at Sonny's tomorrow and see what he says. He's a great guy and always very honest. Been in this business a long, long time. I know I'll get the straight scoop provided he is there!
Stopped ordering super unleaded ???? Is that because its the end of the season and he doesn't want to store it...........or he won't have it at all for next season ??? DETAILS....DETAILS !!!
Hope Direct Marine Fuel has premium fuel for next season !!!
Just found all my fuel receipts for this season....... scarry !!!....and I missed a few trips too.
Don,
BURN THE RECIEPTS .... just think of all the enjoyment....Cant put a price tag on that!
Always add stabilizer, especially with the Ethanol in the gas. If you don't add it, you will end up with gummed up carbs, fuel lines, filters, etc...
It's cheap enough and well worth the money.
